Hi, All!!
I'm back for some more great advice from the knowledgeable Iboats community. I'm slowly restoring a 1969 16ft Starcraft. Recently I sealed and painted the inside of the hull (i'm not sure if I used that term correctly).
My next step is to attach aluminum cross braces to the ribs and center stringer. I've searched Iboats and other forums for how some people have done this and got a few general ideas. This link http://forums.iboats.com/forum/boat-...-fisher-marine shows what I'd like to do. However, I likely won't brace every rib. I was think maybe every 4th rib (unless someone provides a good reason to brace each one). After, I plan to fill the bottom cavity with foam for buoyancy and stability. Kind of like the picture below but, hopefully, a bit more form fitting.
Here's the thing, I can't find any C-channel aluminum at Lowes like the one from the link. I saw some 1/8 inch thick flat aluminum at Lowes http://www.lowes.com/pd/Steelworks-8...at-Bar/3049415 but it's bendable and I'm worried it won't provide the sturdiness I'd like. Oh, and I plan to attach the braces to the ribs with sheet metal screws and attach it to the stringer by way of pop rivits. So here are my questions:
1. Can anyone provide suggestions on what material I should use for my braces and does my plan seem viable?
2. Does anyone have any suggestions on how I can attach a carpeted deck to the cross braces?
3. Have I not considered something with my plan or do you have any advice before I proceed?
Thanks everyone!! Hope to hear some great advice soon.
-Michael
-Michael
