My Tilt/Trim motor went out so I ended up buying a new one. While installing the new motor the receiver fitting on the main tilt piston shattered. I have big plans to hit the water with friends Saturday and do some wakeboarding. I really need the trim but I can do without the tilt. Can I just plug the holes for the tilt and pull the motor up by hand? Or should I build a closed loop between the 2 holes? Will either of these ideas work to get me through the weekend?
Thanks for any ideas you guys may have...
Brent Dooley
86 Bayliner Capri
Brent Dooley
86 Bayliner Capri
