Help choosing prop for 18' cc with 90hp
Gboats91
I have an 18' center console with a 97 90hp johnson outboard. current prop is a 3 blade turning point 13.25x19. The motor only spins up to 4100rpm and about 29mph.
Im looking to try a 15p prop I believe, but im unsure if I can or should change diameter. Does anybody know what the max diameter I could fit on this motor is?
What are some common prop sizes that would work for me? Other manufacturer hubs that fit as well? I would prefer to find some cheaper used props with hubs already for testing purposes.
Also, does anybody know if I have a 13 or 15 spline shaft? I wont be back with the boat until the weekend and id like to source some props by then
Gboats91
97 Johnson 90 J90ELEUA shaft spline count
I have a 97 Johnson 90 J90ELEUA. I'm looking to change props. Does anybody know if the spline count is 13 or 15 on my motor? I won't be with the boat until the weekend and I would like to source a prop by then. I've seen both listed for this motor. Thanks
ahicks
15" sounds small. The 17" would be a much more common size.
If your tach is accurate, the math says a 15"pitch prop is the right one. Hopefully your tach is accurate, and you have a normal load of fuel, people and gear in the boat when you read the tach.
When you pick the pitch of a prop, the diameter is usually chosen for you.
The prop manufacturer will know how many splines you have. Choose the correct hub for your new prop and enjoy.
