Hello everyone!, thanks for taking the time to help. So I finally got to use my Sea Tow after 5 years lol. It paid off though, the tow bill was $1200!!
OK here's my boat info: it's a 20' 1995 Crownline bowrider with a mercruiser 5.0 LX I/O. Carbureted with thunderbolt igniton.
Me and my father were trolling and the boat started to stumble a little. About 5 mins later it stalled. It would still run if I started it an reved it up in neutral, but once a load was put on it(put it in gear) it would stall out. Eventually it just stalled, then wouldn't run anymore.
I have to boat home now. It's tries to sputter and start but won't go. It's not a fuel problem, I believe it's spark related. I put a spark tester between the coil and distributor. It blinks a little dim and everytime it actually tries to start you can notice the tester gets brighter. Also when you turn the key off after cranking it will try to run and you can see the tester is blinking bright.
I don't want to start throwing ignition parts at it, because that could add up quick. If anyone can steer me in the right direction I would greatly appreciate it.
Thanks again!
Cory
Thanks again!
Cory
