Help! beeping wont stop!
Old Hippie
I have a Bass tracker 1998 with a 40 hp Mercury .... dirt dobbers closed the pee hole and I did not notice it till the buzzer went off half way across the lake...cleaned out the hole and water is circulating with good pressure from pee hole and the motor runs fine... i just dont know how to reset buzzer....it is a constant beep ...not intermident...any help would be appreciated.....Thanks
MudSkunk
Re: Help! beeping wont stop!
the plugged hole might have damaged the impeller that sucks in water or might have damaged the pump.
