markymarc1
- Jan 24, 2009
- 5
This 71 Evinrude 6hp Fisherman is new to me.
After putting new plugs and gear oil in, I pulled twenty times, and it finally fired up - for 15 seconds, then fizzled. Twenty more pulls resulted in nothing.
Same thing the next day - ran for fifteen seconds and fizzled, then wouldn't start again.
Based on the advice of the forum, I went to check the compression, to avoid throwing good money after bad. I went to the local auto z*ne and bought a compression tester.
Not sure whether I did this correctly or not. With the motor cold (my only choice considering it won't run) and no fuel line attached:
----I took one spark plug out and screwed the compression tester snugly into the hole. Pulled the starter five times, and got a reading of 60.
----Did the same thing with the second spark plug hole (with the other spark plug back in), and after five pulls the guage read 60 as well.
I remember reading the guage should read close to 100.
Am I testing the compression correctly?
The motor has sat for some time, and the previous owner said it ran the "last time he tried it".
What would you suggest I do to try and improve the compression?
Thanks!
Thanks!
