Re: help aluminum boat leak
posted earler but can't find can anyone tell me what to use to seal leaks along the bottom seam of a basstracker alun revited boat read and tryed several things from the net but no luck staying if anyone can tell me and would like to send reply by e mail thanks send to
pappy7781@att.net not real computer smart but do love to fish
A couple of items, Have you confirmed that the boat is leaking from the rivets? Do you have access to the inside of the boat? meaning is the deck out of the boat and you can access the interior of the rivets. Most of us have used Gluvit to seal from the interior of the boat.
When i did the restore on mine, Gluvit works really well. I haven't seen anybody use anything on the outside of the boat, i've only seen people seal from the inside.
Also Be sure to check the condition of the rivets, if they are loose then i would strongly suggest brazing them prior to the sealant.
Give us some more details as well. How much water is it taking on? pictures of the leaks if you have them, etc..
T
