jgillispie
- May 9, 2009
- 1
Hello, I thought I would post my question here as it seems like there are a lot of knowledgeable people on here. I have both a question and a request for some advice concerning my 1976 Webbcraft. It has a Mercruiser 888, which of course is a Ford 302 2bbl, 188hp. This past weekend I decided to try and take her out to the lake for the first time in at least 4 or 5 years. The last time I attempted to put her in the water she immediately got to temp then over heated so I shut her down and got a tow back to the ramp. So getting her ready for the big weekend last week I replaced the lower unit water pump and also one of the bellows coming from the exhaust riser. I also did a fresh oil change and points replacement. Unfortunately when I got her down the ramp and into the water, to test the water pump replacement, she started right up and purred like a kitten but to my surprise she was pumping huge amounts of water out of the freeze plugs. I shut her off and pulled her back up the ramp and checked and 5 of the 6 plugs were gone. So I replaced those at the lake with the rubber expandable ones from Autozone. After getting those replaced I again pulled her back down the ramp into the water and started her up. Everything was fine no leaks purred like a kitten. While I sat there letting her idle I decided to check the oil dipstick just to be safe and damn if it was milky and 3/4 of the way up the dip stick. So I again shut her off and pulled her out and took her home.
So my question. Before I tear into the engine I wanted to get some feedback. My first thought is that the head gaskets might be blown, but since 5 of the 6 freeze plugs were gone I am afraid something far worse has happened. If anyone of you guys might have some knowledge about these engines I would be greatly appreciative of any thoughts or guidance. I am kinda at a fork in the road per say. Obviously its an old boat that needs work done other than the engine, is it worth the investment of replacing the engine along with the other repairs (upholstery) or do I call it dead and buy a newer boat. I mean I know that as soon as I tear down to the head gaskets I will know if that is the problem or not but I really dont want to waste the time if its 70% plus, likely that the block is cracked. Any thoughts? Suggestions?
Thank you
Jason
Thank you
Jason
