Help a Newbie ID a motor!
88junktruck
Hello everyone<br /><br />I am looking for Help, Info and Advise<br /><br />I was recently given an outboard motor that "used to run great".. how many times have we heard that!<br /><br />The motor is a two cyl. two stroke Evinrude Fleetwin. The only id numbers I can find are on a tag on the transom mount.<br />They are 4417 82638<br /><br />What do I have, were can I get parts, and what should I do first?<br /><br />The motor has been sitting for a long time with gas in it so I don't want to damage it by just starting it up.<br /><br />Any help would be great. As this thing keeps calling to me every time I go in the garage! It is begging to be put on a boat and taken out fishing.<br /><br />Thanks
ob
Re: Help a Newbie ID a motor!
It's a 1947 2 hp .First thing I would recommend is that you obtain a service manual for the engine and go from there.It will likely need to have the carb removed and cleaned of any old gummy deposits.
88junktruck
Wow, I am shocked the motor is so old!<br /> I also can't beleive it is only 2 horse power. I thought for sure it was five or seven because it is so big and a two cyl.<br />Would you know of any sources for manuals and parts?<br /><br />BTW...Thanks
88junktruck
Thanks for the help and the links.<br /><br />Is there another place on the motor I can look to ID it? <br />The person who gave me this motor swears it is a ten hp! <br /><br />I saw a pic on e-bay for a 1952 fleetwin and it looked totaly different. The prop pointed downward at an angle and mine points straight back.<br /><br />I also noticed that the paint color of the motor mount bracket is a slightly different color that the rest of the motor, is it possible that the original mount broke and that a different one was put on instead of repairing the original?<br /><br />Also where does one buy parts for these motors on the web?<br /><br />Thanks again
rickdb1boat
Look on the powerhead for a quarter size (freeze plug looking) welsh plug. May have been painted over, but they a usually silver. Numbers should be on there. And yes, you are correct about it being larger than a 2 HP with 2 Cylinders. Must have changed the bracket somewhere down the road. Look for numbers like these. They are off 10 HP Models from 1956-1963<br />10012<br />10013<br />10014 <br />10015 <br />10017 <br />10016 <br />10018 <br />10019 <br />10020 <br />10021<br />10022<br />10023<br />10024<br />10025<br />10302<br />10303
88junktruck
Well,<br /><br />Thanks again for the info and the links.<br /><br />I found the freeze plug and it has the same number (4447 82638) so I guess it is only a 2 hp. <br />I found some other numbers that may help to be certain of the motors size.<br /><br />The engine block is marked 277059<br />The cyl. heads are marked 203018<br />The carb. (Tillotson) is marked MD54B and 07302<br /><br />I found some other numbers too, boy I wish car parts were all marked like this little motor is!<br /><br />I was able to do a partial dissasembly of the motor and It needs some work!<br /><br />The tank, carb and fuel line are all gummed up.<br /><br />The big thing I found is that the ignition is toasted. Both coils are cracked all over the place, the capacitors are leaking and the plug wires are cracked and the points are all burned up.<br /><br />I now need to find a reputable place to order parts from on line.<br /><br />I also need to find a place to buy the lower motor covers, both of the lower cowling halves are missing. <br /><br />It looks like I have a great project to keep me busy during the long Buffalo winter!
88junktruck
Now I am confused.<br /><br />One place says it is a 1950 7.5 hp<br />another a 1947 2 hp and yet another says it is undetermined...they have the manuals but don't know the hp or year!<br /><br />Can anyone tell from the Carb. or engine block numbers above what this should be?<br /><br />My money is on the 1950 7.5 hp<br /><br />BTW did I mention the tank is mounted to the motor? it is not a remote tank type motor.<br /><br />Thanks
rickdb1boat
88<br /><br />Can you post a few pics of the motor? Many can tell by looking at one what it is. If not, send them to me and I'll post them for you.<br /><br />rickdb1@earthlink.net
rickdb1boat
Does it look like this one:<br /><br />
88junktruck
Hi Again,<br /><br />It looks just like the pic of the FleetWin 7.5 hp.<br /> <br />Although unfortunatly I do not have the lower side covers.<br /><br />I was up late last night surfing the web and I found a few pics of a 1953 Fleetwin 7.5 hp and it is basically the same. So, thanks to your help I am now sure it is a 7.5 hp 1950 Fleetwin.<br /><br />Wich is great news because I plan to build a 14 or 16 foot plywood skiff with my kids and this will be a perfect motor. <br /><br />I have the motor all pulled apart so I don't know if pics will do any good but just to be 101% sure I will snap some this afternoon.<br /><br />Rebuilding, repairing this motor will be a first for me but I can already tell it won't be the last.
Backlash
Not to confuse the issue, but you've got a 1952 7.5 HP. Good luck on the rebuild, they are great little motors.<br />Backlash
