Help a green horn out
trainwrecker22
Ok, I am green to this boating stuff. But I bought one a year ago and it's bean running pretty good. I was wondering where I can find some info out about the outdrive. Here's the Paul Harvey on the motor and out drive.... it is/was a 95 merc 5.0 305 (of358602). That motor let loose. I dropped in a 350 5.7. My question is is the gearing correct in the outdrive and what gearing do I have. How can I find this out? It's a merc apha1 Gen 2 serial OF497376. If anyone could tell me or point me in the direction to find out the help would be appreciated. Also what is proper gearing if not correct
Bt Doctur
guessing the 5.0 used the 1.84 and the 5.7 used 1.50
gear ratio should be stamped in the side of the drive
Yegboats
ENG: 0F358602 450B100HS MERCRUISER 5.0L ALPHA ​
DRV: 0F497376 5010165HS MERCRUISER ALPHA 1.65:1 ​
TRN: 0F515877 6010005HS MERCRUISER ALPHA TRANSOM​
Rick Stephens
1.65 gear ratio was standard on the 5L. You should be fine, probably have to prop up a little.
Rick
thumpar
You should be able to overcome the ratio difference with a prop. They are not that far off. If it is a bigger boat the lower ratio might even work out better.
