Help a family diy guy out please
Four winn probs
Well I took her out today for about 2 hours and quarter tank of gas and she's running like a champ. So the intake it was. Lesson learned. Drain the intake also on volvo 4.3s....
Maclin
Great news :) I was just sure it was the block also, good luck in the seasons ahead.
Four winn probs
I do have a couple questions though.
#1, My speedometer gauge is not working. I do see the wheel in the back with the gear thing on it and it appears to be attached to a wire of sorts. Is there a simple reason to fix n trouble shoot the speed gauge system?
#2, is that my oil pressure hits the red when I'm just a little more than half way into throttle... is this normal?
I have done 4 oil changes with the last one being synthetic 5w30.
I can only assume that if the oil got warmer with the correct thermostat, maybe the oil pressure will go down since it won't be so thick?
#3, My temperature never really gets to the half way mark. It goes from cold to quarter into gauge then right back to cold. I haven't checked the thermostat yet but the mechanic said he believes it doesn't have one. (I bought this intake used with the thermostat housing already on it) so if the boat should run at half gauge then I probably need to check the thermostat but if it's normal or ok, please let me know.
#4, My gas gauge goes from reading what I think to be correct to empty then back randomly. While I had most everything torn apart, we went for a ride in the boat, I unplugged an re-plugged in the fuel sending unit wire and noticed a little bit of corrosion on the plug. We cleaned it and thought it was fixed but it kept acting up. Not sure it I need a new fuel sending unit or just rewire.
Just some questions on my quest to many years of happy boating..Thank you all for any advice you might be able to help me out with.:)
bruceb58
Definitely check the thermostat. I would just go ahead and replace it.
Four winn probs
I am wanting my speed gage to work. I am going to start surfing and need to know how fast were going.
Ayuh,.... It's probably a mechanical gauge, with a pitot tube on the transom,....
Electronic would have a paddle wheel,....
GPS, an antenna,...
Four winn probs
THIS ONE HAS THE PADDLE WHEEL IN THE BACK THAT MOVES AS YOU GO DOWN WATER. HOW CAN I GET THIS THING TO WORK?
Ayuh,.... I guess ya oughta see if there's power to the head unit, 'n if the wires are connected from the sensor,.....
Four winn probs
SO I FALLOWED THE WIRES AND THERE SEEMS TO BE 3 WIRES COMING OUT OF THE BACK TO A PLUG IN THE ENGINE BAY THEN HEAD UP FRONT. UP FRON THEY SEEM TO BE HOOKED UP. THERE IS ONE WIRE OUT OF THE 3 THAT IS BARE WITH NO COATING. IS THIS NORMAL OR DID THE WIRE GET FRIED AND LOSE ITS COATING???? ITS BARE FROM FRONT TO BACK SO I ASSUME IT IS SUPOSED TO BE LIKE THAT. SORRY FOR ALLL CAPS....
captmello
I would post these questions in the electical forum. You might get more help there instead of adding more to this thread. I use my phone as a speedometer on my boat with a free app.
Four winn probs
Taking my 1999 four wins out tomara. From what I've heard on speedo it seems bad electronic connection is 90% time at falt so I unplug an repluged both end connection so well see if that fixes and I swap thermostats with new. So hope all goes well with the fam trip min Yana
Four winn probs
Well for some reason my starter keeps working lose. Can't figure out why but ima put lock washers and locktite on it this time. Took me 45 mins to get it tighten up on water. With fam on boat. Not a good start to our Saturday out. But it ended good. I got some surfing in so cant complain
bruceb58
Are you using Starter Bolts? You should not need loctite or lockwashers on it.
Four winn probs
They look like starter bolts to me. Not sure but don't want to keep going threw that agin. The starter is very hard to get to unless you remove the engine top cover and that sucks......
