Shanes88Force
- May 28, 2007
- 8
Hey everyone, so I've got a '97 90hp Evinrude that came with the Mako that I bought. So far I've replaced the starter, waterpump, lower unit seals, sparkplugs, thermostats and fuel hose/primer bulb. I am running the motor on a portable 6gal tank.
Now the motor will start and run in neutral from 1500-3000rpm, and will push the boat at 10mph before it bogs down and dies. It will not idle nicely. So I decided to start troubleshooting:
Compression: All 4 cylinders have between 105-112psi compression, so they checkout good and within 10%
Spark: All 4 spark plug wires put out a nice thick blue spark with a nice loud "snap" when put close to the block when cranking the motor over.
Fuel: Fuel can be seen in all 4 carb openings when I pump the primer, I pulled the carbs off and cleaned them (found a stuck float needle valve) - looks like they were recently rebuilt as the gaskets looked like new. Nothing else was clogged and all looked good.
Now, when I run the motor, I can pull the plug wires off of the two left side cylinders, and the bottom right side and it will run exactly the same. Thats right the motor will run with just the top right side plug wire attached! - It's only running on one cylinder then! Attaching the other plug wires makes no difference. Pulling out the plugs I can see that they are wet/blackish.
Is this some sort of drastic timing issue where the plugs are firing at really the wrong times? I know there firing, and I know theres fuel. I'm really not sure what to do next?? Maybe do all the tests again and see if I missed something...
Thanks for looking guys,
Shane
Shane
