Help 70 everude less of power
Maddog 40
I have a 75. 70 hp evinrude, #1 cylinder is missing out ,the plug is firing when I pull the plug wire off there's no change in the running, I check the plug and it's wet, but the plug is fireing, changed the coil and the pick up under the flywheel can't figure it out any help
Honorary Supreme Mariner
Carburetor jet blocked ?------Reed valve problems ?-------Compression test needs to be done.
On my tester it would show about 140 psi on each cylinder !
Maddog 40
It's supposed to have around 128 give r take, #1 had just under 90#2 had the same and #3 had just over90
