Help 35 hp.1984 chrysler
roscoe7560
Motor has been sitting for 2+ years lower unit was bad. I replaced the lower unit and it fired up ranabout 15 seconds and wont fire upagain. I tried starting fluid nothing.Motor has spark at both plugs fuel was changed ? Any ideas? Bill
Steve Mahler
Re: Help 35 hp.1984 chrysler
dont use starter fluid on a 2 stroke motor. ever. squirt mix gas from a little bottle.
Anyhow, how are you getting fuel in to the motor? seems very likely that the carb needs a good cleaning. Are the carbs wet?
On my motor, it only needs choke for an instant to start- any more and it will flood. To clear a flooded chrysler, I have found it best to manually open the throttle butterfly wide open, no choke, and crank. May need 2 people...when it catches let go of the butterfly so it doesnt over rev.
roscoe7560
Thanx I am just taking the word that it only sat this long. It sounded good when it fired but then quit. Where does the water come out for the water pump? Top exhaust or bottom or? Bill
