dallen1382
Thread starter- Joined
- Jul 16, 2007
- 1
I am building a boat, 13ft marine ply speedboat weighing approx 210lb ,and am trying to power it with a 16HP briggs and stratton vertical shaft engine coupled to a johnson outboard lower leg that I purchased off ebay.
The gearbox is inj good nick. Gears and bearings are in excellent shape. I am going to bolt the gearbox through the boat using the cavitation plate as a flange.
I am trying to identify the exact age of the gearbox to get O rings and seals.
I may be as old as 1970's. Can anybody help?
It has only 3 bolts holding on the impellor housing and has a non throgh exhaust prop. It also has no thrust bearing on the prop shaft.
Please help.
Regards
Dave
Please help.
Regards
