HELP!!! 2006 Tahoe Tachometer not working
electod22
I have a 2006 Tahoe 4.3 Liter, the tachometer just stopped working can this be tested or should I just replace the Tach
havasuboatman
Ensign
Re: HELP!!! 2006 Tahoe Tachometer not working
You can test a standard type tach. With the ign. on, motor off, make sure the positive terminal has power and neg terminal is grounded. Then briefly ground the sender terminal on the back of the tach while a helper watches the tach needle. It should jump.
