bluechevyy
Thread starter- Joined
- Oct 23, 2009
- 52
2005 Mercury 9.9 four stroke
Please help! I have a 2005 mercury 9.9 4-stroke (OR063010) with electronic ignition, power trim, yada yada yada, all the options. I can not for the life of me get my kicker to run properly at idle. Currently it will start with the choke on, revs up high and then dies. The only way I can get the motor to stay running is standing at the motor and feathering the throttle.
Thus far I have tried the following; I have pulled the carb out and completely disassembled and cleaned all parts about 4 times and scrubed parts with a tooth brush/WD40 ad Carb cleaner. The jets and all are clean. All holes flow carb cleaner freely. I even used some feeler guages where possible and gently pushed them through all of the tiny holes in the carb to ensure they are not full of varnish or build up. I replaced the seals in the carb and reassembled it. I do run stabil in my gas year round and have checked the fuel which is clean and free of water.
I have replaced the fuel line/primer bulb with a new one to verify I'm not pulling air into the fuel system. I have changed the fuel filter ( I did use a more universal filter that I could see through which is slightly larger vs. the original).
I spent much of yesterday messing around with the idle screw and have uncovered the fuel mixture screw to adjust that. Still no luck.
I also installed clear fuel line from the fuel pump to the carb and verified fuel flowing and NO air in the line.
I sprayed carb cleaner around the intake manifold to cylinder head gasket and around the carb to intake gaskets to check for air leaks and got no reaction.
I checked compression on both cylinders and both read almost exactly the same at 150psi.
I changed spark plugs. When I did run the engine I noticed the top cylinder spark plug seems to be very slightly wet and dark colored compared to the bottom one.
What I have is a motor that will start up (cranks over a little longer than I think it should and starts slowly before rpms excellerate) and runs only at extremely high rev'ing speed. If I attempt to back off the idle screw setting it idles down and dies. Also, it will adjust speed by itself. I will just get it to start running at a slightly lower idle and it will rev itself up very high.
Unfortunately, I cannot afford to take this to the shop. I am fully capable of most all repairs on this myself, I just need help figuring out what is going on.
HELP, HELP, HELP, the Mercury guys have run out of ideas to help me!
Thanks so much!
Curt
Thanks so much!
Curt
