I have a 1995 evinrude 150 v6. It is only running on 3 cylinders. I have replaced the coils, optic sensor, new stator, new CDI module, new crank seals, rings and all 6 carbs have been rebuilt. New plugs, when I take a wet plug from a cylinder that is not working and change it for one that is, the wet plug starts working. I even went as far as making a whole new ignition system to run it and still the same 3 cylinders don't work, #2,#3,#4. It is weird because it is 1 cylinder on one bank and 2 cylinders on the other bank I'm ready to give up, I don't know what I'm missing. If anyone can help it would be much appreciated, thanks.
