Help 1987 18 hp evenrude fastwin pisser location
enginedude
I have never owned an older motor before like this I cant find the pisser. I looked everywhere and Cant find one I dont want to mess up the motor. Can someone please help me. I know there are 2 or 4 exhaust holes on the back of the foot. I dont see a steady stream of water anywhere. Please help.
Pony
Re: Help 1987 18 hp evenrude fastwin pisser location
Enginedude-<br /><br />Welcome to iboats. :) <br /><br />For these guys to help you, you will prolly have to post a model number. I dont think they made an 18hp Evinrude/ Johnson in 1987. I'm not entirely positive on that, but pretty sure someone else can verify that.
enginedude
I just purchased the boat and motor I never owned one before but that what they told me and I dont see the model number on it. Im kinda confused because I would have no clue on how to tell what year motor it is. Thank you for the reply
Pony
There should be a little square tag on the transom clasp that has the model and serial numbers on it. It should be on the Port/left side of the motor.<br /><br />When you find it either post it back into this thread or look here and you should find an answer <br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000012;p=1#000004 <br /><br /><br />Edit: also there is a quarter sized metal "welch" plug in the block that should have a number stamped into it.
enginedude
Ok It was serial number 18402D-E05693 Thanks I must have over looked it.
Pony
1964........that seem right to everyone else?? thats what I got.
enginedude
Thanks alot is there a way to post a pic maybe that would help. Im just confused with the pisser. Thanks alot
enginedude
<img src="http://i31.photobucket.com/albums/c379/enginedude/DSC00548.jpg" alt="Image hosting by Photobucket"><br /><br /><img src="http://i31.photobucket.com/albums/c379/enginedude/DSC00553.jpg" alt="Image hosting by Photobucket"><br /><br /><img src="http://i31.photobucket.com/albums/c379/enginedude/DSC00550.jpg" alt="Image hosting by Photobucket"><br /><br />It looks the same here are some pics Hope these help Thank you
itstippy
Nice motor; those electric-starts are sought after. You should get a good flow of water out of the holes in your top pic. The water should be quite warm, like for washing dishes.<br />If you just got the motor and don't know the maintenance history of it you really should drop the lower unit and replace the rubber impeller in the water pump. A new thermostat is a good idea too. That 18HP will run forever if properly maintained - don't be put off by its age. It was built to last and last and last.<br />Scroll to the top of this page, look about 2/3 of the way down, in the center, and you'll see a red "Search" button. Click that and search under "Fastwin Waterpump" or "18HP lower unit" or 18hp impeller" or something similar. Even if you don't do your own work it's good to read up and know the basics of your "new" motor.
enginedude
Ihave the pics on here can anyone tell me where the kill switch is on this motor and how to hook up muffs to run it out the water. Thanks itstippy. I dont have a clue about really anything on this motor. Im trying to learn but no one really has the same motor.
itstippy
Yours has a key switch for the starter where the kill switch button usually is. Someone used the existing hole to mount the ignition switch for the electric starter kit. Take a look at the ignition switch inside the cowl and tell us how many wires are hooked up to it. It may be rigged for both start and kill. If not you may need to use the choke to kill it.<br />You can't really run these 18-20-25 HP's on "muffs". They don't fit. Get a cheap trash can and fill it with water - better anyway because then you get backpressure on the exhaust. Still, though, never run it past high idle unless you're in the lake. Make sure the water in the trash can goes to am inch or two below those idle=relief holes in your top pic that serve as the "pisser".<br />Don't you believe that "no one really has the same motor". They made that motor for about 25 years. There are thousands of them out on the water every day. It's one of the most popular fishing motors ever built.
enginedude
There are two wires hooked up to the back of the ignition switch.ok and the guy told me the motor ran about a year ago and I craked it up trying to use a 5 gallon bucket no water comming out so I shut it off. What do yall recommend me doing with this motor before I take it out fishing. Thank yall for history on this motor I was really worrying about it. What ever info you guys have to offer I am all ears.
enginedude
Also where could I order parts like a thermostat, rubberimpeller,manual etc. Thanks again for your help.
itstippy
A five gallon pail will work but you'd have to remove the prop and put something under the bucket to raise it up high enough on the motor. The water's gotta come up to within an inch or two of those idle relief holes. Look at where the water level would be if the boat were in the water with you sitting in the back - the water pump's gotta be submerged or it'll just suck air.<br />It sounds like you need to familiarize yourself with the basics of 2 cycle outboards. They are very different from 4 stroke lawnmowers and such. There is an excellent post in the Engine FAQ's for you to read:<br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000033 <br />I dunno about being told the motor was a 1987. There's nothing wrong with a 1964 - in fact I love them and they're very well made, but the guy that sold it to you should have told you what you were buying. So check it over good mechanically before going out in the middle of the lake with it. That seller was not trustworthy and it's up to you to find and fix any flaws.
enginedude
what about the kill switch there were two wires attached to starter switch. Is it rigged fokill also
itstippy
With just two wires going to that key switch it probably just runs the starter solenoid. <br />Stand on the starboard side of the motor - the side with the forward/neutral/reverse shift lever. On top of the motor is the pull start/recoil housing. Under that is the round flywheel with the gear teeth on it all the way around. Under that is the magneto - also round and a little smaller in diameter than the flywheel. That magneto should have two black wires coming out the bottom. Those are the kill wires - they ground out the points. See 'em? Where do they go?
enginedude
Thanks bro GTG to work Ill be on here tomorrow Thanks alot for your help. Ill checkand put it on here tomorrow. Thanks again bro.
enginedude
I looked under the Magneto and there are two black wires running under it they run the screw looking switch above the starter switch. Which you could see from the picture I sent. My guess would be thats the kill switch but what do you think. The last motor I worked on was a f-16 motor no an marine motor so if I sound stupid sorry. lol.
tashasdaddy
enginedude , kencook.com has all your manuals. highly recommend you order them and study them. you will have a better understanding and it won't be nearly as frustrating. i have a 1955 15 hp evinrude i will never sell. run it every week. as far as ear muffs walmart sells a SeaSense muff with a rectangular rubber muff that fits my 15hp the round one will not work. i use it just to flush out any unwant crud i may have picked up while running.
