Help!!! 1980 Chrysler 115
tacmedic
I have a 1980 Chrysler 115 that is giving me issues. On the water hose it runs like a champ, but in the water it is a turd!!! Won't idle and acts like it don't want to get up and go. when you throttle off it just dies!! Any ideas???
tacmedic
Re: Help!!! 1980 Chrysler 115
Compression good. Manual no. New plugs today. Idle speed 800-1000
foodfisher
Idle speed should be 750-800, in gear, in water (not muffs, need the resistance). Fuel pump diaphram may be torn or stretched.
jerryjerry05
Set the air screws on the carbs.
Turn in till just bottoms out.GENTLY>
Then out 1 turn.
What is the comp#s?
