Help!,1975 johnson stinger arching around spark plugs
adam1psu
Re: Help!,1975 johnson stinger arching around spark plugs
there is no adjustment on the testor but from what i am told there should be a bright blue spark seen even in the daylight
adam1psu
PROBLEM SOLVED! I re-thought everything and went over the engine once more.i noticed a black spot where it looked burnt on the block. there was a loose ground there and now it runs great after tightening the loose wire.
ezeke
I am very happy that you posted the solution and that you worked it out.
I think that a lot of money is wasted because people don't take the time to check and to clean the wiring.
fireman57
adam, glad you found it and posted your solution too. Just got back from out of town and your's was the first thread I opened. always like to see good news.
adam1psu
thanks for the help, i agree, logical deduction can solve a lot of problems if one has knowledge and patience. i am far from a marine mechanic and have allready learned a lot from you guys by just asking questions or reading. unfortunately my problems continue on another thread:'(
