HELP 1966 Evinrude 40hp
scotty78
Hello all.
Ok so I got myself a 1966 Evinrude 40hp to play around with. It's a awesome looking motor. I want to try and get it running and think there are bits missing like the coils and maybe the generator (generator which in not to worried about) and maybe the wiring boxing? I'll admit straight up i dont know alot a outboard motors but heard the early ones are pretty easy to work with.. Iv taken some photos so if you notice anything missing let me know. Also if anyone knows where I could download a repair manual for this motor that would be awesome. I'm really looking forward to getting this motor going hopefully.. Thanks for any help
Honorary Supreme Mariner
The coils are under the flywheel.---It is the electric shift model and you must have the generator in working order !-------Do you have all the wiring and controls ?----Before you spend one $ on it do the following.---Compression test.-----Check operation of shift electro magnets.---Remove bypass covers ( behind fuel pump ) and inspect pistons and rings.
F_R
1966 does not use a wiring junction box. Solenoid and voltage regulator are mounted under the hood on that model. Both are missing. (Regulator is a $100 item.)
scotty78
Thanks so much for the reply guys. I do have the wiring for it including what looks like the button box thing, the wiring however has been cut on pretty much everything . I have a feeling maybe iv bitten off more than i can chow with this motor. It only cost me $70.
oldboat1
^^would also be inclined to part it out. Be nice if you knew whether it was shifting, but the l.u. can be worth some bucks, likewise the push button control unit (Do some comparison shopping on eBay). Would be good to get a complete unit, manual shift model.
