Help 140hp johnson motor wont turn off!!!
karsandiego
I need help my 1988 140hp Johnson once started revs at full speed and when i turn the key off it stays on? i had to pull all the wires off the plugs to stop it can anyone help me with this problem?:confused:
tashasdaddy
Re: Help 140hp johnson motor wont turn off!!!
stuck timing plate??
bankerjohn
Does this only occur when you re-start a hot motor? .... if so, search this forum for "thermal runaway"
If this happens when you start a cold motor, how quickly does it get to WOT?
Kill switch has no effect?
Maybe a few more specific details would help diagnose.
