Help 05 2 stroke merc stalls at idol and while shifting
terrence o
2 stroke merc stalls at idol and while shifting cant figure out why it is a 90hp and has been properly serviced by a merc certified mechanic dont know if it is the carbs or what stalls while you are trying to shift and if you put it netural after about 10-15 seconds and I have to choke every start or it will stall. This motor is way more trouble then it is worth love it at high rpms but at low rpms major problems may sell but i dont want to
bootle
Re: Help 05 2 stroke merc stalls at idol and while shifting
If carbs have been properly cleaned and adjusted, check and make sure that all of your fuel lines are tight with no air leaks, and your fuel tank is properly venting.
The fuel pump could also be the culprit.
terrence o
hey thanks alot that is another thing that i never had thought of with the fuel pump/line
