Hello all. I have just purchased a 2014 Suntracker 22 XP3 with the mercury 150hp four stroke. I should be picking it up by the end if next week and ready to hit the lake. Have to also admit - I'm new to this all.
I have a couple questions. The specs list two weights - approx weight (2840 lbs) and approx package weight (4631 lbs). I imagine the first is the dry weight of the boat, but what is the package weight? Boat on trailer? I'm trying to figure out what I need to tow this thing. I shouldn't have to tow it often, but when I do, I want it to be safe. I've found the motor is about 500-550 lbs, but can't find any data on the tracker 2 axle trailer.
I'm looking at the 2014 Acura MDX and the 2014 Audi Q7. The Acura has a towing capacity of 5500 lbs while the Audi is rated for 6600 lbs. I like the tech in the Acura, but I'm just concerned that the towing capacity and shorter wheel base would make for a bad tow. I do like the Audi, but still not sure if it's up to the task either.
Any advice or experiences would be greatly appreciated.
Thanks in advance.
Thanks in advance.
