HELLA Marine lights
The lights on my T-Top are old and not working so I decided to hunt fer some new ones. A local CL listing had some HELLA lights - 1 new and 2 used but good shape - so I picked them up for cheap. $40. I hooked them up to the 12V supply when I got home and dang if those babies are blindingly bright! Geebus :surprise:
Any of you guys used HELLA? My guess is they will take a bigger gauged wire to the power source.
Re: HELLA Marine lights
Ayuh,.... How many watts ya talkin',..??
jc55
Are they LED's or halogens? If they're the 55w style of halogen, 2 of them would run around 9 amps. I'd run them off of relays to keep the load off of your accessories (daisy chained switches) but probably not necessary. Others will weigh in.
MH Hawker
Not to mention the battery drain and you can only use then for docking, any other use can get you a citation and will **** off ever one else on the water.
They are 55w halogen.
"you can only use then for docking, any other use can get you a citation and will **** off ever one else on the water."
That's true but I don't plan on using them like headlights. They point down to the deck.
Hella is a large OEM manufacturer of lights supplying the world. nearly every German car made has Hella, along with about 50% of the off highway market. being 55 watt, they will be bright
jc55
Yes, on the schematic. Have you considered LED's? two 18w=3 amps draw, no relays, and super bright.
I was looking at LEDs and found some nice ones (small) for about $70 bucks. These:
Nice but at $70 I was looking at $140 and these were $40 for 3. My guess is I could CL them for a more.
jc55
I bought those in black for $19 each. What's happening is that LED's are big money. There is an offshore manufacturer under selling everyone so bad, that vendors are buying it, doubling the price and reselling. The $19 lights I bought a month ago are now $23.90 each.(I won't give the vendor and violate iboats policy) I replaced a rear deck 55w halogen with one. I have it on a switch, the alarm unlock lights it for 30 seconds and it flashes when the alarm is triggered.
It's also a solid, heavy aluminum casting. Pretty unbelievable actually.
sam am I
Ran some offroad Hella's in my 4x4, no prob's ever.
