Heat sensor horn
ronb3
I have a 1990 Johnson 88HP Special which I bought new and have maintained well. Five years ago, the heat sensor for one side of the block kept going off w/o a heat problem. We disconnected it and all has been well. Now the other side is doing the same thing. There is a solid stream of cool water coming from the weep hole. However there was an odor of a small electrical fire coming from the throttle console and a small amount of smoke. I pulled off the assembly and saw now indication of a fire or a short. I then ran the boat for an hour w/o any problems. Do I dare disconnect the last heat sensor and any ideas on what caused the burning? Ron
OBJ
Re: Heat sensor horn
Ron..<br /><br />You DO NOT want to run the engine without ANY of the heat sensors disconnected.<br /><br />Get hold of a wiring schematic for the rig and track down the short or what ever caused the smoking problem. Pull the warning horn and see what's up. The short may have been within the control box itself. Very tight area in there.<br /><br />Keep us posted....Thanks.
