The Remedy II
- Jun 16, 2011
- 16
Greetings friends,
My Volvo 225D/280 has what seems to be a heat exchanger on it. It is leaking water out the port side gasket. The part is L shaped. It pumps out at faucet speed, there is cork on the outside. Replacing the gasket is well within my mechanical ability, but the identification is the problem.
The only writing on the part says "Cepro type Dwv". On the top of the aircleaner it says " Babron corp 5775", "T or 1ooa. "Uscg app no 162.041 190/9". Any help in identifying the correct replacement gasket would greatly appreciated.
Will any gasket work? I put coolant into this "heat axchanger" yet it leaks water out the side seal.:facepalm:
The end is a circle with one bolt and cork surrounding it.
Who sells these gaskets?
Any knowledge would be greatly aprreciated.
Regards,
Mike
Regards,
Mike
