Head swap
Captionwiz
I've recently purchased a 1983 Aeroglass Phantom with ano Evinrude E75TRLCTE 75hp 3 cylinder motor. I have found that the cylinder head #0323682 is damaged and pretty much impossible to find a replacement but have found a #0323681 head from a 70hp motor. Are these interchangeable and what will this so to performance? The bore and stroke are identical so I assume hp rating was done in head design or intake design. I am restoring this boat and would like to keep as close to original including motor, any suggestions?
sutor623
HP rating was due to carb and exhaust modification. That 70hp head will work just fine.
emdsapmgr
Likely you will find that the 75 head may have slightly smaller chambers, making for slightly higher compression. Likely it will work just fine.
F_R
Honorary Supreme Mariner
The part numbers are different, so there is a difference in the part--somewhere. Most likely it is in compression ratio, but that's an assumption. What I'm wondering is what is the nature of the damage? Can we assume (there we go again) it isn't damage caused by some other failure in the engine?
