head not working
wetbar
I have a 340 sundancer that the head is not working. I can hear the pump running in the engine room but, it doesnt sound like it is running full speed. Normally I can hear the white looking tube thingie sucking. I pushed the switch at the end of tube thing and heard a click so I think the pressure switch is working. I checked the duck bills they look OK. Even with the duck bills out it did not work. If it was the DB I would think it would just run all the time. I pulled the pressure switch off the white thingie, looked ok. when I put it back I noticeed when I pushed it in it cut off the little pumping noise. . . So maybe it is the pressure switch. I am not sure what to check next. Any clues? What voltage should be at the white tank thingie? Thank for the help.
slasmith1
Re: head not working
Disconnect the hose from the outlet side of the head (not the pump) and see if you hear what sounds like a vacuum leak if so let all the pressure bleed off reconnect the hose and turn the pump back on and re-test the system. some times if some one tries to flush without waiting for the pump to completletly cycle (two flusher) this will happen I have two kids who don't always follow directions so I have had this happen a couple times. if this doesn't work then you have a problem with one of your pressure switches or a blockage somewhere.
