AnkorCraft79
Thread starter- Joined
- Aug 18, 2010
- 11
I have a 1979 Mercruiser 120 4cyl and my book says 130 ft/lbs for GMC motor and 90 ft/lbs for Mercruiser. I know the motor is a GM product so which one is it. I'm thinking the 90 lbs is correct? I had a leaking exhaust valve on #2 cyl. New exhaust valves and lapping all the others should do the trick. Is the adjustment like the old GM's, tight enough to run, 1/4 turn down after ticking starts to 1 full turn. Mark
