Ive changed the shift rod connector drained the gear oil no metal shavings everything seems tight but still will not hold in forward gear when I give it throttle 1977 35hp johnson seahorse
Yes they were I'm thinking I have some cable adjusting issues I'm not quiet sure though I've tried cheating the shift lever forward and adjusting the cable to cheat forward gear nothing work but out of water with rabbit ears on it it runs and goes in gear just fine but once you drop it in the river and pressure hits the prop once you get half throttle it kicks out of gear
I was wondering if there is anyway to adjust the shift linkage through the peep hole where the brass coupler connects say maybe tightening the upper rod by turning clockwise
Brass coupler/shift connector won't be where you tighten the actual shift rod. The slot only allows you to lock it in place via that small bolt. I wouldn't over tighten. Within the exhaust housing under the power head pan is another shift lever that is actuated by the external shifter. You can see it when the L.U is dropped by peeking up the housing with a flashlight. When you shift into FWD is there any type of play or wiggle with the shifter itself?
When it shifts into forward gear the prop hub seems tight by hand when you turn the prop out of water the flywheel turns and seems pretty tight also and what your saying is I may have to drop the Lu to adjust shift rod
You need to look at post #6 and answer that question before you start turning wrenches; mark the hub of the prop and then drop ion the lake when it slips or pops out of gear look at the line; if it has moved then you have a spun prop. Good luck
Yea I have thought that myself but I didn't want hassle with dropping the lower unit but sometimes I'm not that lucky. Thanks all you men for the help I'll have to pull the lower and check the dog and after that I'll let ya know what I've found thanks again.
Just reading through much material, is it possible that T.Ryan's OB could have a worn bellcrank. That could result in 'sloppy" shifting and cause the clutch components to wear and develop shifting problems, most notably the clutch dog and ears.
Just assembled a gearcase like yours this afternoon.----If lower shift rod is not screwed all the way in it can have an affect on forward gear engagement.
I have an old 25hp 1976 model evinrude with sheer pin prop would the dog fit out of that one into my johnson or a lot different gear case my johnson has thru hub exhaust
Parts might work use shop.evinride.com to see if p/n's match on the two models. If I recall turning shift rod counter would back it out of the gear case so you would to turn clockwise to tigten. I don't know for sure racerone will be able to answer for sure
