Having second thoughts
vinsdusky
I just bid on and won a viper propeller on Ebay and now I'm not sure if it's going to fit . the propeller is a viper ranger fishing bass part #176627. I want to put it on a new etec 200 Ho. It was stated as a OMC 15 splines. 14 3/4 X 19 propeller. Can i get some input on if this prop is going to fit/ Thanks in advance.
vinsdusky
Re: Having second thoughts
Isn't there anyone out their that can help.....
Randybeall
Go to the manufacturer web site and look to see if that number prop will work on your engine. I don't know but the information is out there for sure.
Dhadley
What don't you think will work? I'm sure you questioned the seller, what did he say?
That prop will fit the 1" 15 spline OMC / BRP propshafts. Isn't that what you have?
erlindbl
It will fit...... It's the same prop as the new viper (#763918) but it has the old rubber hub instead of the new TBX one.
vinsdusky
I will run it this weekend. Thank you all for the responses
