dawsoncreekforce125
Thread starter- Joined
- Dec 10, 2012
- 8
ok heres the layout of my problem.... boat was working pretty good,
i was cruzing about 45 mph and had to slow down for a bridge and after the bridge the motor would only drag ***. so i get home and start testing things like compression spark. compression was good spark wasnt, so i was getting spark on the bottom two cylinders only. so i reversed the two cdi pack wires only going to the coils from top 2 to the bottom 2 cylinders. then i had no spark at the bottom cylinders and i did have spark on the top. so i thought my cdi pack was bad bought a used one on ebay no change in the problem. read some forums to find out my stator was bad. only giving power to one of my cdi packs. changed the stator now have all 4 coils getting spark but no change in the water still slow. cleaned carbs new gaskets for them. changed diaphram check hoses gas etc. still the same old slow. wondering if my trigger/sensor is bad. try the ohms test, readings were in range. dont have a dva meter. also checked all wires and grounds. changed rectifier. the only thing left i think it could be is the trigger/sensor.
help anyone please :facepalm:
