having high rpm and no speed form motor
helixice
i got a 1983 charger bass boat with a 1988 140 hp Johnson 4v outboard 2 stroke . went out to the lake and was getting high rpms but boat was moving as if I was in a no wake zone with the leveler all the way down it started shacking bad. I have no idea what it would be and would love any feed back as to what would cuz this and how to fix the problem
Most likely a spun prop hub. To verify, draw a line across the hub and nut with a permenant marker and take boat for a spin. If the line moves, new prop hub is what you need
tpenfield
+1 to spun propeller hub. What 'leveler' was all the way down :noidea:
I'll try Googling 'shacking' . . . maybe you mean shaking :thumb:
