Have you used your Tahoe inshore?
mandopickr
I'm going to Charleston in a few weeks, and have thought about taking my Q6 to day tour the islands along the coast during mild conditions. How big a seas have you experienced in your Tahoe?
cioffin
Re: Have you used your Tahoe inshore?
How did this work out for you?
I have a Q7i (2007) that Im thinking of taking to Ocean City MD. It would mostly be on the bay side, but I might venture out of the inlet for some better fishing if it looks safe enough. I have only used it in fresh water lakes so far, but I see no reason it couldnt handle some close to shore sea fishing.
Anyway, let me know how your experience was.
whmoore18
Any updates on you guys running inshore with these boats?
sstacey
I actually wrote this in an earlier reply.... actually for whmooore18....
I use my Tahoe 215CC for both bass fishing on Lake Simcoe, Ontario, Canada and for Salmon Fishing on the Great Lake Ontario in Canada. Have two downriggers attached to a gimble mount on each side that rests in each rear rod holder.
I have taken the Tahoe out in rough weather with white caps and 1 to 3's and 1 to 5's. Let me rephrase that statement. I have brought the Tahoe IN during such weather......I can honestly say I'd avoid the larger ones but still thought I would share as its also true that many don't know what their boats are capable of. I've been around boats on and off for most of my life. My father has had footitis since I was a teen, working from a 16 foot bowrider up to his current 70'.
As for the Tahoe, my pride multi-purpose boat, I have actually had rogue waves that broke over the bow and caught me, standing behind the center console. The water rushes through the center hold infront of the console, and the remainder rushes to the back. Depending on the water amount, it can build at the back, as it works its way out the rear. In the meantime, your bilge pump light is running steady.
25 minutes later I have managed my way back to port and within a minute or two, the bilge pump light goes out and I'm looking over my shoulder at those white caps I just navigated.
Each season I learn a little bit more about the limits of the boat, as well as my own. Its a combination of common sense, knowing what to do and being prepared.
PrinceValium
It would be those rougue waves I would be worried about! I don't think I would be able to do the swells. I have yet to take my boat to the salt water and don't know if I ever will. I don't know anything about the ocean and would be worried something would happen and leave me stranded. I know the boat is sound...but it's just the unknown element. If I had a bigger boat it would be a possibility.
I will however go on the Delta which is brackish water soon.
