I have a 90's model Gamefisher 15 hp. It has run great for the year that I have owned it. I took it out yesterday and fished all day and it did fine. Today I took it out and started up river and after about 2 minutes it died. It would start back up and idle but when I put it in forward it died every time. I messed with it for an hour before I gave up. Later today I messed with it and found that if I pumped the bulb real hard and fast when I put it in forward, it would run good. So I thought that my bulb or line was bad, so I replaced them, but the problem was the same. If I pump the bulb when I put it in forward it will run good for a while then die. If I keep pumping it it runs good. Does anyone have any ideas what it could be????
