j4gwig
- Aug 7, 2010
- 25
I just replaced plugs wires,changed points out to electric ignition system,took boat out last weekend for the first time this year and it was running very rough,checked oil and had water in it,I changed the oil and started it on the muffs and again water in the oil,I noticed that there was a bolt taken out of the intake manifold,and was not put back in,I replaced the bolt,changed oil again and still milky,so my question is can anything else cause water in oil,and that bolt being out of the intake and running the boat could the gasket be toast,,or is the head gasket toast,the boat has never overheated..
