Keith luke
- Jun 15, 2022
- 6
Have 2000 sea ray signature 190 cuddy 5.0 L Trim works on down and trailering not up. Any ideas what’s the problem and how to fix
Hello and welcome to iboats.Have 2000 sea ray signature 190 cuddy 5.0 L Trim works on down and trailering not up. Any ideas what’s the problem and how to fix
so someone said to change the up selinoid
There's very little in the circuit that could be destroyed, apart from the fuse. Check that.. But there shouldn't be any red wire on a negative ternimal (unless a previous person has been in there changing wires around).which i did and no change then mistakenly attached a wire to positive post on battery which should have been on negative post. It was a red wire and now have nothing. no up down or trailering. now what do I do. can,t even take motor up to bring in to get fixed by certified people
Why not check both?would that be the 20 amp in line fuse or the big 150 that is on the solinoids
What is 'wire #103'?wire # 103 is the one
thats the number on the red wire I put on positive terminal that caused the problem
