Has anyone used "airplane paint" to paint a hull?
billh1963
It is suposedly super tough and much cheaper than re-gelcoating. I'd be interested in hearing if anyone has any experience with the stuff.<br /><br />Thanks!
Hooty
Re: Has anyone used "airplane paint" to paint a hull?
Anything is better then re-gelcoating. There is beaucoup paint that will do a super job. The urethanes are probably the best.<br /><br />c/6<br />Hooty
crab bait
aircraft paint such as imron,, is SO NOT user friendly..major health an safety consids. ..let alone safety equip. ..
airman
A friend of mine painted his boat a few years back in a colour that is remarkably similar to the planes he works on. Not that I'm implying anything. ;) His experience has been good and he applied it with a roller. Make sure you get a good mask at the very least.
Hooty
A teacher pointed out once that there is nothing toxic. Only toxic limits.<br /><br />c/6<br />Hooty
ThomWV
How long will it take the School Board to get that idiot out looking for a job he can handel. I don't know of anything much more stupid that a teacher could have told any student, other than that self inflicted gun shots might feel good.<br /><br />Imron is often used on aircraft, cars, and boats. It is a fine paint with great reflective qualities, a hard finish that will last for years and years (probably outlast a gelcoat to tell the truth) and comes in any color you can immagine. A second choice would be Awl Grip, also formulated for boats and aircraft. Its a little different than Imron in that its a little more dangerous to use, and it finshes to a surface that you do not rub and buff out, never compound, and never wax. It is far and away best reflective paint around and can be applied by roller with great success. You are going to pay for this though. The primer you need to use cost very close to $200 a gallon and the top coat paint cost a lot closer to $300. Oh, when I say gallon I mean a gallon of the product, but with the primer you also add an equal amount of hardner and then 25% or more of reducer. With the top coat the ratio becomes 1:.5:.25~.4 so you are going to get a lot of coverage out of it. Of course its also available by the quart but the per unit price goes up. I've been buying my Awl Grip supplies from Performance Yachts in Annapolis, MD. The have the best prices I've found.<br /><br />Imron can be found at most large auto parts stores that specialize in supplying the local auto body repair tradesmen. It is commonly available and great stuff. You could use either and still be way way ahead of a replacement gel coat, which is quite a job to apply for a full hull.<br /><br />Thom<br /><br />Thom
I Think what Hooty meant was,
A teacher pointed out once that Everything is toxic,<br /> The Only Question is, What are the toxic limits.<br />
BTW, I've had Great results with Urethane......<br />Buy it right down at NAPA.... MSU is what they call it.... $100.gal or so.... Mix Any Color you want....<br />I prefer to Spray it myself...
Hooty
(Sigh) <br />Thanks Bondo. You handeled that very well. ;) <br /><br />c/6<br />Hooty
Captn Dave
I used Interlux's two part epoxy to paint the deck of my boat and have had great results. It's been on for several years in the hot Florida sun and is holding up great. It's really tough stuff. I had to use a razor to remove some drips. It's not cheap though. Maybe up to $50 bucks a quart now. But that's cheaper than Awlgrip or Imron. <br />As with anything like this, preparation is 90% of the job. The kit comes with a video too. Laying it down on flat surfaces is easy. On vertical surfaces, it's more tricky.
ob15
I painted my boat (homemade stitch & glue) with System Three LPU. Their paint is specifically designed for marine use and is water based. LPU's can be very dangerous if the right safety equipment is not used. The cost is about $85 per gallon. Can be rolled, brushed or sprayed. Very tough also. The best thing is it cleans up with water and is pretty much non toxic.<br /><br />www.systemthree.com<br /><br />To buy<br /><br /> http://boatbuildercentral.com/
dabble73
Hey Dave do you think that this product could be applied ontop of a gel coat?
ob15
I think it can but am not sure. The surface prep will be the key. I would fire off an email to S3. Their tech support is great.
