NetDoc
- Aug 20, 2011
- 517
I have been working hard on this 1968 Fibra and was going to launch it this weekend. Today, I was going to run a temp gauge when I noticed that the v-belt was upside down and on top of the upper pulley. Closer inspection revealed that lower pulley was way out of alignment with everything else. ARRRRRGH! I want to get my boat ONTO the water.
It appears that the front motor mount will have to be removed in order to have enough space to remove the pulley. In order to do this, I feel that the engine should be supported before I remove the mountings. I have a 2X6 and will be constructing a support beam from gunnel to gunnel using 2X4s to steady the 2X6 edgeways. I will be using an anchor chain to hold a come-a-long to provide the support I need to remove the front engine support. Anyone see a potential problem that I am overlooking? Is there an easier way to accomplish this?
FWIW, I will be replacing the water pump while I am in there. No need to tempt the fates with an old one.
