Hard to accelerate
partsrowe
2007 Yamaha 50 outboard oil injected
The issue is that the motor starts and idles perfectly.
When the motor is cold acceleration is normal
After stopping for 5-10 minutes this happens.
Starts easy and idles fine
When accelerating to fast engine will die. If you put it into gear it will move the boat slowly and if you very, very slowly accelerate pushing the throttle back and forth you can regain normal speed.
I am suspect that the oil is mixing to heavy. It also has started to miss, and I replaced the plugs. The miss did come back after a few hours of riding around.
Ideas?
