Gary Hines
Thread starter- Joined
- Aug 12, 2015
- 1
We have a Evinrude 1990 V88 special out board ,2 stroke engine.. This thing has a terrible starting issue. You have to pump up the primer bulb, a lot then the battery goes dead from cranking it over and not starting. Jump the Battery Crank longer then finally starts. Then when it does start you have to hold the throttle 1/2 throttle to start, The Things we have done, ,,, rebuilt Carburetors,, replaced fuel line and primer , New plugs , new wires,... Compression 115 lbs. per cylinder
I'm thinking on putting a electric fuel pump on it to help with the starting issue... Any help would be appreciated.
My Buddies say spend 10,000 dollars buy a new Four stroke motor . The it will start.. LOL
