Hangkai 6hp T6
KC9000
Had a client put really bad gas in the onboard tank and ran it for 15 minutes and he said it just stopped. The gas had floating stuff. He said it was one of the pre mix cans of 50:1. These Hangkai motors are similar to the tohatsu motors. I have this T6 Hangkai that will start on full throttle only and it's a hard start and will only barely stay running barely putting. Starve the engine and as it runs out of gas it picks up right before it runs out of gas. Out of ideas. Cleaned all fuel lines and put a new fuel filter on. Cleaned carb 3 times. Soaked it in pine sol for 3 days fully submerged totally pulled apart. Blew it out with 100 psi. Checked compression 120. Checked coil it tested good. Pulled flywheel did not shear flywheel key. Starting to think this may be the pump diaphram has a small hole? Or something intake related? Any ideas would be helpful. Hope I'm not posting in wrong spot. I am gonna tell my clients no more hangkai motors lol 😆
