Half power after warm
surfisher
I have a 1997 50hp johnson a 16ft Wellcraft that has always run great. Just out of the blue it has started acting up as far as power, fine one day, not the next.
When I initially take the boat out it gets up on plane and will stay on plane as long as I care to run it. However once the motor gets warm and I slow down it will not come up on plane again. It will get up to about 3000 rpm's and plow like crazy but won't turn enough to plane out again. It does misfire occasionally when running like this but not too bad. It idles smoothly before and after it gets warm, that is not affected.
It had been smoking heavily when running so I thought that maybe the vro pump was pumping too much oil. I did change out the pump and it did help with the amount of exhaust but I still have the issue. I tried running a somewhat hotter plug and did not make a difference either.All voltages are good with power pac and stater, equal compression in both cylinders, no starting issues. All I have to do is let it cool for a few hours and it will run fine again until I slow down after it gets warm.
I'm lost, just wondering if anybody has any ideas or has had this issue.
Bosunsmate
look at your plugs, see if one is fouled.
sounds like a failing electronic component. It happens with electronics that they start failing first when warm but work ok when cold.
Try a spark test on each cylinder when hot
surfisher
I did change plugs today just in case, none had been fouled before this and these aren't now. Both cylinders are firing as they should.cold and hot. I agree with the electronic diagnosis but I have tested everything I can think of. Thank you for replying and any other input is appreciated
surfisher
Motor runs steady at 100 degrees, never has run any hotter. I'm in southwest Florida with a water temp of 91 degrees, you would think hotter but not. Brand new thermostat and guage too.
oldboat1
hmm. would be on the cold side for sure. 130-140F would be warm to touch -- could hold your hand on the top of the head for a few seconds. Using an infrared gun to get a temp, or from the gauge?
surfisher
Using the gauge, it does get warm and you can hold your hand on it for a few seconds but not more.
oldboat1
That sounds right (sounds like the gauge is registering a little lower than actual).
boobie
Do a cylinder drop test on it when it acts up and see which cylinder is the problem child.
BrettNC
What boobie said. You really need to determine which cylinders are drooping out to start a diagnosis.
oldboat1
need a timing gun and a helper/driver -- clamp on the plug wires when it's acting up, and see which one isn't firing or firing erratically.
boobie
You can also pull one plug wire at a time with an insulated pliers.
surfisher
Well, no issues with plugs/plug wires. The boat is not missing at all now but will not come up to speed again. Put in another new set pf plugs, firing fine. Ran it on plane for 1/2 hour, slowed to idle and that's it. It will only come up to 3000 rpms and plows. I at one point tilted the motor up enough for the rpms to jump up and lowered the motor and it went fie, tried it the second time and I'm back to half power. I'm grasping here for sure.
BrettNC
A cylinder drop test indicates which cylinder is not firing at a given time. Couple of ways to do it. You can use a timing light, connecting it to all plug wires, one by one, until you see the inactive plug wire.
You can also disconnect each wire, one by one, noting how the motor responds. The wire or wires with no change will usually indicate the problem cylinder.
recka81
My 65HP was acting a bit like this and it turned out to be the stator.
