SteveDavis
- Jun 15, 2007
- 74
So, first time on the water this year and BAM! Water is coming into my boat. It's not the plug. When I looked under my engine and towards the transom, it appears to have been coming in around there. When I got home, I put on the muffs and gave it a go. With engine off and muffs pumping, everything seemed ok. After I started the engine, I noticed a lot of water being let out, by the bottom of where the outdrive comes through the transom. Seems to be the same place some exhaust is exiting, prior I thought it all came through the prop hub. Anyhow I don't know if they are both related or not, but no water built up in the boat while I had the muffs on. What could be my problem? I need to fix soon, as I have a trip to Rainy Lake planned.
Thanks in advance!
Steve
Thanks in advance!
Steve
