Guys, use your killswitch laynyard.
marcoalza
Re: Guys, use your killswitch laynyard.
Still, I will not use one. If you use common sense, you won't need to use it...
My friend, accidents can happen no matter how careful you are. I'm sure you are a careful boater but unfortunately, there are others that aren't and they use the same waters as all of us.
As I metioned above, I only used mine in rough seas but after reading the story above I will use it all the time - not just for my sake but for the family and anyone else who is within reach of that nasty, nasty twirly thing.
Steve Marsh
Still, I will not use one. If you use common sense, you won't need to use it... IE. When I go to the bow or on the swimstep of my boat, I put the engine in neutral.
Let's hope these are not famous last words. You are relying on other people to have common sense.... very risky.
WastinGas
Yikes def sad to see. i wasnt aware of folks being air lifed for non life threatening causes?!?!?
emilsr
I don't come up on plane without the kill switch lanyard any more. Have seen too many incidents that were preventable. The jet ski guys have a velcro strap that goes around your wrist and attaches to the lanyard cable; that's a good option if you don't have a d ring to attach the lanyard to.
Now if I can just train myself to put the PFD on before planing I'll be good to go.
JoLin
Not to stir the pot, but why is a kill switch only on an outboard and not an I/O? As others mentioned, the prop blade is turning...regardless whether it's an I/O, OB or IB.
It isn't only on outboards. My current boat has two.
My 24' Chris Craft (V-P 5.7) had one, too. Spent the first season clipping it to my belt when conditions were rough. In the off-season, I needed to remove the ignition switch to fix a connection- that's when I found out the kill switch wasn't connected to anything. :redface:
jrs_diesel
Wouldn't be a bad idea to test them occasionally. :)
I have 3 outboards, but only one has a kill switch (they're small outboards). I have planned on installing a kill switch on the two that don't have one.
D
DJ
Guest
I ALWAYS use it. It's like second nature, just as seat belts, in the car.
I've had people qustion me. My reply: "hey, do know where we are, do you know how to operate the boat, can you drag me into the boat???"
They understand, after that.
DaNinja
It's habit now. Like a seatbelt, I don't feel right without it. I also tell my passengers that if they see me at the helm without the lanyard attached, they are free to bring it to my attention. I think only the admiral has ever made that correction...once.
JoLin
It was a 'DUH ! ' moment for sure, what else can I say?
