ctswf
- Aug 7, 2012
- 424
I'm about to build rod storage under the gunwale of my aluminum starcraft, with most racks I have seen it looks like the reels will be rubbing against the walls. What's the normal solution to this?
I was thinking either add a little padding on the walls so the reels aren't banging as hard, or perhaps a little nub for the reels bracket to reset against which would keep them offset and tilted away from the wall...if that makes sense, a photo would describe that better.
I use medium to large saltwater spinning reels and definitely foresee possible reel damage from the bails banging on the walls.
