GT 150 VRO 1987
Colekeeler
I just bought johnson 150 VRO and installed on my 18 foot boat VRO has been removed I mixed gas for it. Starts good but idles rough . On the water it misses and moves slow until it suddenly comes to life and runs great for short time. Does this several times for couple miles then runs fine. Took off carbs ran small wire into every orifice cleaned with carb cleaner.(seen that posted on this forum) filled with high test gas and sea foam. Ran exactly the same. Mechanic thinks maybe coil. On Right track? Any ideas Thanks
Honorary Supreme Mariner
I guess it was not a carburetor problem------------Run with a timing light and see if you can possibly find an ignition problem.
emdsapmgr
Agree. Intermittent problems like you are experiencing are more typical of ignition faults. The 6 coils on that engine are usually pretty reliable, but one could be causing a problem. Fortunately, you can do testing on this yourself. If you detect one plug is not firing, ( timing light test) you can swap the coil with one that is working. See what happens. If you have multiple misfiring plugs on one head, you can swap the two power packs. One controls the spark to each head. Swapping them to see if the problem moves to the other head will tell you something. In addition, that system also has a stator and timer base, both of which are expensive and worth testing before you just spend your $ on replacement parts. For further excellent troubleshooting info, go to the troubleshooting guide found on this website: cdielectronics.com
