Hi all! Ive done searches on replacing the floor in my '69 Larson Shark and Im in the process of cutting out the floor. I used a circular saw (carbide blade) for the long cuts. Now Im needing to get close to the side of the hull. In searching the forums, I read that people use grinders to get in tight, close to the hull places. My question is...what kind of grinder specifically? I have 3 ideas in mind, but just not sure if one will work better than the others.<br /><br />1. 1/4" Air Die Grinder<br />2. 4" Air Angle Grinder<br />3. 3" High Speed Air Cutter<br /><br />Just from looking at them, my choice would be the 1/4" die grinder. Any other thoughts?<br /><br />Thanks in advance!<br /><br />Captn---
